Race inside input shaft
Old Jan 29, 2017 | 05:36 PM
FIVEPOINT7's Avatar
Default Race inside input shaft
Is there a shim under the race that's in the input shaft?
Old Jan 29, 2017 | 08:09 PM
AMP-D's Avatar
No, there shouldn't be anything under that race.
Old Jan 29, 2017 | 08:12 PM
FIVEPOINT7's Avatar
I'm having an issue right now, something is causing the input shaft to be too far away from the 3/4 synchro, causing the slider to slide too far and lock into gear when the keys start to come out. Any ideas?
Old Jan 30, 2017 | 08:00 AM
AMP-D's Avatar
Is it a new or used input shaft?
Old Jan 30, 2017 | 11:57 AM
FIVEPOINT7's Avatar
Stock 160k mile input shaft. LT1 car if it matters.
Old Jan 30, 2017 | 08:14 PM
jmd's Avatar
jmd
Shims are done between the front case adapter place and the outer race for the input shaft big bearing. Follow the factory rebuild guide and figure out what thickness you need. You should be well under 0.100".
Shifting an unassembled unit and hoping you shift it just enough to not pop the keys out is accomplishing nothing. Clock the retainer spring correctly, billet keys are a good thing and put it together.
