Reverse Lockout Not Grounding?
My question is, if the wire is not broken or open, is there a easy way to fix the computer side of things or can only a tuner possibly fix that issue.
My last resort is to wire my own ground to the solenoid but I prefer not to add an ugly switch or drill a hole in the center console for a switch. Any advice?
On my a4-> M6 swap I could never get the bastard to work correctly. Even during tuning it would operate opposite of how I wanted it to work. So I just left it un plugged and put an extra spring in the base of the Hurst shifter
Im def using the right connector because it had green and pink wiring to it. I think I may just get a round switch and mount it inside that flip up cover.
Prettt crazy how much trouble a tiny solenoid can cause and the force you need when it is not cooperating. I can't wait to take a picture with my middle finger and the solenoid.
