New clutch ???
Old Jul 18, 2017 | 04:55 PM
BobH's Avatar
Default New clutch ???
Have to fix real seal on 99 LS1 so I am going to replace clutch , pressure plate and throw out bearing while apart. Motor is stock and maybe put a few minor upgrades in future.
Looked at LS7 set up but it appears that it is slightly larger than LS1/LS6 pressure plate requiring a flywheel change also. That being said is worth the change to put an LS6 clutch and pressure plate set-up in there?
Other recommendations would be appreciated...Aftermarket is okay but do want to exceed 400 total.
Thanks
BobH
Old Jul 20, 2017 | 05:11 PM
stevieturbo's Avatar
If you arent making any extra power and your existing clutch was working fine, then just replace it with another stock clutch ?
Old Jul 21, 2017 | 08:58 PM
BobH's Avatar
Thanks....Kinda came to that decision also
