LS3 with a TKO 600 (what clutch/flywheel)
I have an LS3 with a TKO 600 and was wondering what clutch kit/flywheel you guys using ? I just found out from McLeod that I can NOT use an LS7 clutch kit with their TO bearing. The TO bearing will NOT function properly with that "ratcheting" clutch/pressure plate.
I was now going to use the McLeod Flywheel Part#460530 and a RAM clutch Part# 88931HDX.
