Reverse lock out solenoid
Here's a thread of someone with a similar issue. I'm not sure of what this actually accomplished. Maybe it's a manual switch, now? https://ls1tech.com/forums/manual-tr...-solenoid.html
I used a plug from an electrical box with a rubber seal to seal the hole. Works perfect.
The T56....without RLO you can buzz (read grind gears) up shifting into 5th. Yes some have the "feel" down and don't but in aggressive shifting situations your 100% attention may be on other aspects of driving
I had some tunnel conflict when I swapped from A4 to T56 with the RLO....just used a small ball end hammer to "massage" the tunnel enough for clearance. No big deal at all
