Pro 5.0 Question
would recenter itself to the 3/4 gate so I'm assuming it's an issue with the 5.0. Does it just need to be broken in?
what a load of *****, it was even worse than my B&M Shifter !
I actually ended up refitting the stock shifter as it had a stronger centering action than any I tried. 1/2 to middle is ok 5/6 maybe not quite as strong, but no big deal.
it's a little stiffer when cold than after it has warmed up when it's much better.
My 99TA's Pro 5.0 still snaps to center of 3/4. It's about 18 years old and still as the same as when new.
It was good with the stock T56 & clutch and is near perfect with the T56 Magnum & McCloud RXT clutch. My stock shift was total garbage... more of a stock *******, than a shifter.
The B&M's shifters on LT1 and LS1 I've tried were better than stock for sure but weaker on 3/4 centering than the Pro 5.0 in all cases. Same for the Hurst.
I'm still impressed enough with the Pro 5.0 that my 91 RS got one during resto-mod.
