Please help a T56 newb
Trying to decide whether to just run the transmission as it sits to start out or if I should go ahead and rebuild it while it's out. I've been reading and watching youtube videos so I'm starting to get a better understanding of how everything works.
I took the front plate off last night but I haven't been brave enough to disassemble any more than that yet. This may be a really dumb question but can you guys guesstimate the condition of the transmission just by looking at the below pictures of the input and counter shaft gears? I know it doesn't show anything about what shape the synchronizer parts are in.
If these pics aren't useful at all can anyone tell me what I might dig into so that I can really know what condition everything is in but still be able to put it back together without screwing something up?
Before I removed the front plate, I could wiggle the input shaft side to side just a bit but it didn't seem excessive. Trying to push the shaft in and out I couldn't feel any movement but I've read that the expected play is really small, like a few thousandths, so I don't know if I would be able to feel out of spec and needing a shim or not.
Thanks a ton for any help.
-Chris
Input shaft gear
Counter shaft gear
Bought a T56 with 80K on it to us in a drivetrain swap situation.
Had the same internal debate about having it rebuilt before installing it in my swap.
Ended up deciding to go ahead and install it as purchased with my justification being that if it works well, fine and I will have saved myself about $1000.
If not, it is no huge deal to pull the transmission to have it gone thru.
Maybe 4 or 5 hours of personal time and a few weeks with the car not running while waiting for the rebuild.
The other thing is that with a swap there are usually a laundry list of things that will need to be changed or tweaked so if the transmission works but needs rebuilt it would be one of the verified things on your list.
Not the front plate.
If you know the box and it was working fine, just leave it alone.
Parts to refresh an old box like that can soon add up and may be hard to justify if there wasnt anything wrong in the first place.
I just want to know what I really have here. I've read enough to know that digging in deeper means putting the front plate back on and going at it from the other end. I just don't know if I can judge the wear on gears and such unless they are so bad that there isn't any more flat area at the tips or something
I've had a few thoughts about selling this transmission and buying a magnum instead. So that's another reason I would like to know the real condition.
Probably silly of me to hope anything meaningful could be seen from those two pictures. But it was easy to post and ask so no harm done.
Unless there was a major issue there, the only way to get a good idea is with a proper stripdown.
Or just drive it and if it works, it works.
I would button it back up and use it as is.
Yeah that is no guarantee all is fine but there are really no signals that there is a problem. If the fluid that came out had glitter in it...than deeper inspection would be advised
The input shaft movement you describe sounds "normal"
If I want to run a T56 Magnum I really need to decide that now, right? Is my understanding correct that switching to the magnum later would require redoing my cross member and driveshaft unless I spend more for a F Body version?
As I mentioned, this is going into an S-10 pickup.
I'm probably just going to use the F-body trans I've already got. I don't really need the power handling of the magnum but I keep reading about how nice they shift and that's what makes me want one.
