Replaced clutch assembly now clutch pedal issues
Just replaced the pressure plate, clutch disk, flywheel, and throwout bearing on my setup. (2002 LQ4, GTO T56). Bought the replacement setup for a 2005 GTO. Put it all together without issues.
Using a stock F-body master/slave cylinder. Clutch pedal isn't right now, it moves 1/2 way with very little effort, then starts to engage. Pedal bottoms out before clutch releases all the way.
Is this just air in the master/slave? I bled about 6-8 oz of fluid through it, until it started coming out clean, no air came out.
Any ideas?
Any ideas?
