Clutch pedal suddenly goes to floor
What I did was open the reservoir where you add fluid. Put some rags around it so you don't spill any onto the paint. Remove the rubber plunger inside the reservoir and fill it with fluid. Take your Mighty vac setup and find the right fitting to insert down into the bottom of the reservoir and start pulling vacuum.
As you draw the air from the system it will be replaced with the fluid. I would press the clutch pedal in a couple of times also to move any trapped air. Just keep pulling a vacuum and adding fluid until you are drawing only fluid into the Mighty Vac line to its reservoir and no more air bubbles.
To bleed the slave will take two people but if you can find something to hold the clutch pedal down it can be done by yourself.
Procedure:
1) Open bleed screw
2) Press in the clutch pedal and hold
3) Close bleed screw
4) Let off the clutch pedal
Repeat this procedure to get any air that may be trapped in the slave cylinder. You will most likely need to add more fluid to you MC reservoir once your done bleeding the slave. Hope this helps!
Procedure:
1) Open bleed screw
Good news - I was able to retrieve the errant 5/16" socket from the bell housing - had to cut some metal in the trans tunnel to get proper access. Also made it a one man bleeding operation. will likely tack some sheet metal back over the hole when all is done. Have to clean up a couple of things, finish bleeding, and should be good to go. Thanks all for your advice.
Moderator
Received 1,835 Likes
Originally Posted by xny1989
job done - took for a test drive and shifting was nice and smooth. Onward to the next challenge - replace stock, 18 year old exhaust manifolds with headers! My biggest concern is getting the old bolts out, intact.
Gonna do poly mounts while you're in there?
