RAM steel flywheel with Mcleod RST
Any one using a RAM steel flywheel with the Mcleod RST or RXT clutch??, I just need to make sure before buying one. I can't buy the one with the flywheel already with it because of 1. too expensive and I already have a flywheel, 2. I have a 8 bolt crank that uses a flywheel that only fit crate engine applications.
