flywheelspacer t56 ??
Old Nov 16, 2017 | 01:42 PM
Mechanic a's Avatar
Default flywheelspacer t56 ??
hi I am building a ls3 with a callies crank and that has the short rear flange and I want to put a t56 behind it do I need the oem spacer behind the flex plate?? my machine shop wants everything to recheck my balance so.... im also looking at McLeod flywheels and see them offering a stock size an .200 and a .400 thicker
Old Nov 16, 2017 | 11:00 PM
Mechanic a's Avatar
looks like no spacer for a t56 but why is there a thicker flywheels available ??
Old Nov 19, 2017 | 04:37 PM
stevieturbo's Avatar
If McLeod offer them, ask them !
Never heard of it myself.
Old Dec 22, 2017 | 07:15 PM
Timberland's Avatar
The reason they offer different thicknesses is the mating at the crank is off from one engine and crank to another as is the stack up of flywheel, clutch pressure plate. Dial indicate measure the crank flange face to the back of the block. Now dial indicate measure from the throw out bearing to the bell housing face. That make up is the stack thickness you're looking for.... flywheel, pressure plate thickness and clutch. For instance... My Flywheel thickness crank mounting to clutch face measures .800 ...you'll find these all over the range.
Old Dec 25, 2017 | 09:38 AM
garys 68's Avatar
The 0.4" thicker is used in trucks with manual trans. It can also be used on the LS block when mating it to an earlier gen manual trans (Muncie, T10, TKO, Richmond, etc).
