Tick Master Leaking
I installed mine about a month ago as part of a motor replacement and found a small puddle of fluid under the master a week or so later.
I tighten them all before they leave so they are positioned correctly (on the f-bodies). Theres a chance it could have been broken lose when installed....
I was going to try and take a pic, but the wiring harness is blocking the fittings that I want to show. I was able to get a standard combo wrench in on the fittings just enough to turn them a fraction of a turn, but it looks to have been enough.
Hate to dig up a post, but have the same issue, Installed today and tried to bleed only to find it would leak and suck a large amount of air from that fitting into the tilton unit when applying a vacuum. The fitting that seems snug, but never tightens??? at first I thought it was just that loose but after what seemed like the 2nd turn I realized the fitting probably has bad threads? Can't really put too much leverage on it in the car so I doubt I was the one that stripped it, but my only hope is that the body of that tilton is steel and now all I need is a fitting. I'll be calling Monday morning to see what can be done.
I'm pretty upset because I am one person doing this and to get all that way after an hour to find a bad fitting is not how I wanted to spend my afternoon.
I just bought this one and I'm pretty sure all I need is that blue fitting. If it comes to it and I just dropped 330 on a paper weight, I'll look at other options, but hopefully Tick can help me out here.Just troubling that it looked like this one was assembled pretty quickly and not run through QC. I should have tested it before I put it in. I did block off the res feed and push the rod and heard the air leak before I put it in. I just thought it was me not being able to hold the air back. I didn't have to muscle anything in either so that line did not get loosened that way. I pulled the line and fitting and the threads on that fitting failed. not galled or stripped, but snapped off clean and running around in there like fingernails. Reached out to Tick and will hopefully get a resolution this coming week.
Well, yesterday the team at Tick asked I remove the whole thing and send it back to make sure nothing else was damaged. They turned it around and I'll have the replacement tomorrow. Excellent customer service!
No show on the part. Tracking number shows it never was scanned, therefore there is no tracking info for it. So holding out hope it is just caught in the holiday shipping mix and will eventually show up but my talk with Tick's shipping dept didn't leave me feeling warm and fuzzy if it doesn't.
