2006 GTO clutch randomly gone
Old 11-23-2017 | 09:44 PM
camaroLS1power's Avatar
Default 2006 GTO clutch randomly gone
Car only has 50k miles i just bought it...was sitting for 5 years but I have been driving it just fine for weeks.
Went outside to start it and wouldn't go into ANY gear and the clutch pedal was soft. This is strange considering it wasn't slipping and ran beautifully the night before.
Only thing I can think of is it got really cold last night did the fluid lines contract?
Going to try and drain, replace, and bleed the system in the morning...
Old 11-23-2017 | 09:54 PM
Sounds like you might have a leak in the line, or the master OR slave cyl. has failed.
Old 11-23-2017 | 09:57 PM
brandon6.0's Avatar
line could have broke or something busted. Check your clutch master cylinder under hood. Line come off of my buddies gto a week ago. basically had same issue.
Old 11-23-2017 | 10:06 PM
How'd he fix it? Where was the line off??
Old 11-24-2017 | 02:35 AM
dreadpirateroberts's Avatar
it's likely your slave cylinder seal. had this happen before. had a small, manageable leak, and one very cold night it vomited everything out. i am sure the seal contracted and make the leak much worse.
check your clutch reservoir level, it's probably dry.
Old 11-24-2017 | 07:34 AM
It's not dry that's the strange thing.
