Help picking transmission
my turbo nova is using a d&d built t56....so far it's been good but I know I'm borrowed time when I turn it up
The 4L80 overdrive is a second choice. It might not break the bank if your harness and computer originally came from the vehicle with the 4L80. Otherwise its a separate controller for over a grand. Nothing cheep works behind 600 hp unless you have 7" tires on it. Then whats the point unless it's fire burn outs.
At only 600hp, many have made a stock T56 last a long time. Of course you'd be buying used, so there is always an element of a gamble there.
Presumably as asking in the manual forum it is a manual trans you want, and not an auto ?
