TR6060 swap help
Old Feb 3, 2018 | 06:04 PM
field57's Avatar
Default TR6060 swap help
I have been looking for information on tr6060 swaps and they don't seem to be very popular. I have access to one for a great deal from a 15 zl1 totally complete with clutch and hydraulics. I realize they require a custom drive shaft. Is it necessary to run a cooler? Or can the factory inlet/outlets be capped? Do they have a vss plug for a speedo? And i was also curious about adapting the slave cylinder to an aftermarket master cylinder such as wilwood to make the swap possible in a classic car. Any help from people that have done this swap would be great, thanks.
Old Feb 3, 2018 | 07:47 PM
LLLosingit's Avatar
You can loop the cooler lines but considering how cheap coolers are it would make sense to run one. You can't cap them....Looped line at minimum.
Yes they have a VSS for speedo.
With my swap into an S10 I used the stock S10 clutch master with the stock Camaro slave with an aftermarket braided.
http://www.tickperformance.com/tick-...015-camaro-ss/
This is what I used to connect my stock 2-piece driveshaft to the TR6060
http://www.driveshaftshop.com/drives...nger-05-06-gto
Old Feb 3, 2018 | 08:40 PM
field57's Avatar
thank you! Are you happy with the trans? Are you running a factory clutch?
Old Feb 3, 2018 | 10:51 PM
LLLosingit's Avatar
Yeah I'm happy with it, Nice short smooth shifts and yes factory clutch but I will be upgrading because I'm making way to much torque for it. I'm running a LSA supercharger.
