dot 5 fluid in Mcleod t/o bearing
I bought a car and the previous owner used Dot 5 silicon fluid in the hyd. system, McLeod says do not use dot 5, any one used dot 5 and did you have problems ? I may just go ahead and clean and reseal the master and t/o bearing, but would like to avoid if it is not an issue.
Any one ?
Any one ?
