Clip on line
the clip that holds the line in the side of the transmission from the master cylinder fell off and the line came out resulting in a dead pedal. Trans was just put in a lil over a year ago. Is there a way to buy just that clip and can it be put back in without dropping the tranny???
So yes that is a large crack.
It also looks like both the metal retaining clip inside the slave quick release is missing, as well as the plastic collar on the car side that is used to release it.
No idea if you can buy the metal bit separately, but there's bound to be loads of guys with old ones knocking about from old slaves.
Monster and no doubt GM will sell the plastic collar for the hose side.
http://monsterclutches.com/1998-2002...aulic-retainer
they didnt just just do the clutch, they put the complete tranny in, no lower bolts at all. Asking what they are gonna do about it now.
so I would need this retainer and still need that u shaped clip?
You need this metal part inside the QD fitting...in order for it to actually lock together.
http://www.pro-touring.com/attachmen...1&d=1325445469
