Starter difference
Old Mar 21, 2018 | 07:54 AM
Wesley Jack Land's Avatar
Default Starter difference
Gathering parts for my t56 swap into my rcsb silverado. I bought a 2005 GTO trans for good price. From what i read the gto and ls1 have difference starters correct? The gto is slightly smaller and the bell house on t56 has a smaller opening than a f-body. So the question is do i swap to a ls1 bell house and use my lq9 starter or keep current gto bell house and buy a gto starter? I have heard both sides here but they were old posts. thanks
Old Mar 21, 2018 | 02:25 PM
CattleAc's Avatar
Or, go with option 3...modify your GTO bellhousing to accept the LQ9 starter...
Old Mar 21, 2018 | 04:32 PM
Just notch it out huh. That doesn't look all too bad. Would save me some money but just add a little labor which isnt bad. What tool did you use, dremel?
Old Mar 21, 2018 | 06:21 PM
CattleAc's Avatar
I used a full sized air grinder with an aluminum cutting bit...just went really slow when I got close to breaking the surface.
Old Mar 22, 2018 | 08:49 AM
thank you sir!
