Bleeding Master Cylinder with Car Level
Old Mar 30, 2018 | 11:47 AM
69z-28's Avatar
Default Bleeding Master Cylinder with Car Level
Tried search and came up with nothing. I'll be changing my fluid and bleeding the system on my 00 T/A, but just realized I only currently have two jackstands. Will this make a significant impact on bleeding the system with only the front of the car raised? My gut tells me no but it was a random thought I had while getting prepared to do this. Thoughts or experience?..... Thank you!
Old Mar 30, 2018 | 06:44 PM
stevieturbo's Avatar
I dont think you could physically get the car at an angle where it would matter....and if you did...the car would be rolling over and fucked lol
Old Apr 1, 2018 | 09:10 AM
joyridin''s Avatar
Huh? Are you trying to gravity bleed everything?
Old Apr 2, 2018 | 12:33 PM
69z-28's Avatar
I'm just curious if the angle of the front end up only would create enough of an issue with the amount of space left in the master cylinder that it would cause an issue once the front was lowered down....
