Quicktime Bellhousing Users
Dialing mine in and i'm getting a max of .009" Total Indicator Reading (.0045" halved) in one direction, and .002" in the other.
Am i just lucky? Did i finally have something work out ok? I took the dial indicator setup apart, and was able to recreate on the same spots. Is this uncommon?
Update: i ordered a set of 0.007" offset pins, i'm going to get this thing dialed before bolting it up.
I installed the 0.007 pins, adjusted them and have a total of 0.005" runout.
All set for now. The bolts that go into the oil pan threads don't engage far enough in. I ended up stripping out of of the threads during testing. I'm installing a thread insert tonight.
http://www.robbmcperformance.com/products/dowels.html
Lakewood also has a pin and bushing kit, where you drill out the holes, center the BH, then TIG weld the bushing on.
