Flywheel Alignment on Crank - LS1
Old May 7, 2018 | 10:01 AM
r0b2's Avatar
Default Flywheel Alignment on Crank - LS1
Hello!
Hopefully this is an easy question. I fitted my flywheel last night and this morning I noticed I'd managed to fit it without aligning the dowel hole to the crank. I've googled this a little this morning and struggled to find a definitive answer to whether it's a problem or not.. Is it important to have this hole lined up?
As I understand it from googling, the hole is for an alignment dowel, and possibly might have been used on corvettes that have a matched flywheel (with weights added to balance?) however on the camaro/firebird applications this isn't the case.
So by that logic the flywheel
orientation isn't important? I wanted to get some opinions before I go ahead and bolt the clutch to the back of it tomorrow. The flywheel bolts are torqued up and loctited in, so I would prefer to leave them that way if it's not an issue. Picture below
Cheers
Rob
Old May 7, 2018 | 04:19 PM
BALLSS's Avatar
IDK id you motor is "neutral" balanced but if it is and the FW is also neutral balanced...it does not mater the mounting orientation
If however it is a rear external balanced motor...than yeah FW orientation matters
Old May 9, 2018 | 05:03 PM
r0b2's Avatar
Hi, thanks for the quick reply. It's just a standard LS1, no additional balancing completed.
I'd guess normal Camaro LS1s are internally balanced and the flywheels are neutral? Is that right?
Cheers
Rob
Old May 9, 2018 | 06:14 PM
BALLSS's Avatar
IDK about the LSx if it is internal or external balance. LT1 is external (rear)
if you don't have any vibration with motor running...all good
Old May 10, 2018 | 07:48 AM
stevieturbo's Avatar
I've never seen or heard of any dowels on the flywheel on any of these engines ?
So it does seem a bit odd both the hole is there and flywheels seem to have it too.
Old May 14, 2018 | 08:18 AM
Ping King's Avatar
It's been about 13 years since i had the flywheel off of my engine. I thought i had lost the dowel. I don't thinks it's required.
