McLeod MC bracket snapped in half
That's right, the bracket between the Wilwood cylinder and the firewall completely snapped in half! What the literal F? I've had this thing for 6 years and it's never given me trouble until today. I wasn't even shifting hard, just a normal drive. I would think that even if the hydraulics were hydro-locked, the MC or slave seals would let go before this bracket. The only thing I can figure is that it's a casting defect that finally let go. Needless to say, I'm not too happy right now. Has anyone seen this before?
You try and buy the good stuff and sometimes it just shiats because whoever downstream of the sales side did a half **** job welding
The bracket is made by a third party. I agree, that weld is crap. It should have been welded there and all the way around on the outside edge. I just hope nobody else is driving around with one of these half-assed brackets in their cars.I'll try getting in touch with Billy, I think he's who helped me out before.
I'll try getting in touch with Billy, I think he's who helped me out before.[/QUOTE]
..I have the McLeod MC, came in their Street Twin kit. 13/16".
Email Billy with pics.
I see the adapter is now "red" anodized and the piston rod is threaded at both ends where before it just slid on bottom rod connection where you just used loc-tite, if anything, to hold it on. Once mounted it had no where to go but I feel the new threaded bottom end (shaft coming out of MC) is better
My McLeod/Wilwood MC has been in for years now and no issues...hope it stays that way
I have a twin disc that requires their 13/16" bore one....but some do use it for single disc clutches but the pedal travel will be slightly shorter to disengage clutch as you are moving a higher volume of fluid per stroke
part # for the 13/16" is 139305
Thank you for the number! I am between a 13/16 or a 3/4
https://www.summitracing.com/parts/mcl-139310
If you are getting a RST that is a "push" type clutch that uses a hydraulic T.O. bearing around tranny snout and a MC on pedal assembly. IDK what the 139310 is made for but RST or RXT twin disc clutches, according to McLeod, want a stock size bore MC
