T56 ID tag + bell housing help
Old 05-28-2018 | 10:26 PM
Simone36's Avatar
Default T56 ID tag + bell housing help
2561561 F0112
1386 020 D 25968
June 1st, 2001 2nd shift (if i'm reading this correctly)
did this trans come from a 2001 camaro?
How do i know what to search for in a bell housing? This T56 will be paired up to a LQ4 6.0
Thanks for any help, I'm very new to all of this!
Old 06-02-2018 | 01:03 PM
jmd's Avatar
jmd
Yes.
you can set up with the pilot bearing, flywheel, clutch, slave cylinder, and bellhousing for a 2001 Camaro to keep things straightforward,
Old 06-02-2018 | 02:32 PM
Simone36's Avatar
Thank you jmd, I appreciate the help!
