T56 Engaging While Clutch Pressed In
Old Aug 24, 2018 | 10:08 AM
Kring_Z28's Avatar
Default T56 Engaging While Clutch Pressed In
ALCON,
Good morning. Reaching out for some opinions. I have a T56 in my 98 Camaro, fresh rebuild, everything replaced down to the master cylinder and line. I've had no issues for about 3500 miles, then all of the sudden after a nice night cruise and actually getting it up into 6th gear, when I came to a light and put it into 1st and had the clutch pressed to the floor, I had some grinding/rattling start like it was trying to engage first. Mind you the clutch pedal was to the floor. I drained the clutch fluid, replaced it with some fresh fluid and bled the system again and it seemed fine for a few days, but now it is doing it again. Any ideas on what might be causing this? The clutch I put in was a stage 2 diamond clutch if that info helps at all... Thanks in advance for any time/assistance provided.
Old Aug 24, 2018 | 02:40 PM
BALLSS's Avatar
so is the issue grinding while trying to get in gear?
if you bleed system and that fixed it but it started again that could be a leak in your hydraulics which will cause engagement issues or if you are in gear and have the clutch all the way pushed in and car wants to creep forward or stall than the clutch is not disengaging which is typically a hydraulic issue
Old Aug 24, 2018 | 09:56 PM
Kring_Z28's Avatar
It's when it's in gear at an idle with the clutch pedal pressed to the floor, if you take it out of gear, the noise goes away. And it's like it only does it after you drive it a while, it's fine when the car is cold or just doing quick short trips.
Old Aug 24, 2018 | 09:58 PM
Kring_Z28's Avatar
And it doesn't grind going into the gear, just when it's in gear with the clutch held in. Shifts up perfectly fine, but I noticed when it starts to do that, sometimes it acts like it doesn't want to let me down shift... It's weird, I'm stumped.
Old Aug 24, 2018 | 10:57 PM
BALLSS's Avatar
what year car
Old Aug 26, 2018 | 02:21 PM
Kring_Z28's Avatar
what year car
It's a 1998
Old Aug 26, 2018 | 04:00 PM
BALLSS's Avatar
could be a issue with slave or PP...you won't know until you pull tranny & look. Take a look at pilot bearing also when tranny is out
does it make the noise with clutch "almost" pushed all the way down?
