Warped Quicktime Bellhousing Spacer Plate
New spacer plate was warped some too. Not as much as the old one, but enough to be worried about. Decided to cut the plate to make sure there was no interference this time. I know I'll lose some protection, but there isn't really much protection to begin with the LS version. Other plates almost entirely cover the motor, but not on this one.
New spacer plate RM-8020
Cut circular pattern off
Thats what I would have done too, a little trim and go. Your right too that the block saver plate isn't doing much saving in the LS style but the bell is WELL worth the peace of mind to me. I had issues with my Mcleod on my BBC with regards to spacing that I did not check prior to installation that caused me grief so before I installed the Qucktime I took some detailed measurements. Heres some pics to show how accurate the fitment is. I've been very pleased with mine, numerous clutches, ten years later and all good. About 1/4mm difference between the two in stack height with the block saver plate. I dont think removing it will be wise without using a spacer to make up the difference
Quick update. The new transmission and clutch have been back in for a few weeks now with the trimmed spacer plate. With spacer, bell, and clutch assembly all bolted up the A measurement was 2.104". The B measurement on the slave was 1.938". So 2.104" - 1.938" = 0.166" which was right in the sweet spot.
The thinnest slave shim Tick sells is 0.055" so that would made it 0.111" which probably would have worked too, but it's smaller than the recommend minimum of 0.125" to account for clutch wear. And there will be lots of clutch wear.
