you guys with poly or solid engine mounts
Old Jan 18, 2019 | 08:55 AM
Goeatpaiste's Avatar
Originally Posted by 00PewterSS
I have had the trans out a number of times with poly mounts. I use about 4 feet of extensions and it isn't really that bad... well with the car on a lift. I've never bashed my floor or anything. Hardest bolt for me is the torque arm top clam shell bolt, I hate trying to get that in and out.
same. About 3’ of extensions to get a decent angle past the tail shaft and some massaging of the universal (swivel) attached to a short 15mm socket. It’s not “easy” with poly mounts, but it’s also not hard. Just some trial/error, and sometimes swearing and throwing things when the laws of physics defy our need to correctly align on the bolt head lol
a small impact gun helps a LOT as well. If you don’t own a 150$ battery powered impact then I’d suggest get one
stevo
Old Jan 18, 2019 | 07:04 PM
Floorman279's Avatar
Originally Posted by blkbird
I have the prothane motor mounts as well. Just found it easier than fighting those damn bolts from below.
ok so i didn't no that.....you had issues getting to the bell bolts with the prothane?
Old Jan 18, 2019 | 07:05 PM
lol i could use an impact, i have a black and decker 20 volt that can barely crack loose freshly torqued valley cover bolts at 18 lbs
Old Jan 19, 2019 | 12:29 PM
blkbird's Avatar
You can get to them, its just a hassle and takes some patience and some looooong extension with a swivel like everyone has stated.
Old Jan 22, 2019 | 01:00 PM
03Sssnake's Avatar
sounds like a worst case scenario but will keep in mind. that may be something for the solid mount guys though, much better than lowering the k member imo
I have UMI solids and have to loosen the k-member bolts to remove the t56 and to stab it, especially the latter. I can actually pull the trans without loosening the kmember bolts, but no way in hell was I going to get it stabbed without loosening the bolts.
