you guys with poly or solid engine mounts
Old Jan 7, 2019 | 09:55 PM
Floorman279's Avatar
Default you guys with poly or solid engine mounts
how in the hell are you doing clutch swaps? with the factory rubber mounts, it hangs down pretty far with the trans crossbrace removed, but still a little tough for the top bell bolts. but i feel with poly it wont go down enough and solid forget it....
Old Jan 8, 2019 | 08:30 PM
JD_AMG's Avatar
I replaced mine last year (2017), it was a total bitch, I have poly mounts. I think the only one I had real trouble with was the very top center one, in which I used a small swivel extension that I taped up so it wouldn't swivel too freely, and taped the socket to it so it wouldn't come off, and then a regular ~6" straight extension connected to that. I think I started to thread the bolt in by hand and then got the socket on it and used an electric drill to get it as tight as I could. Also I took a hammer to the underside of the car to massage some of the areas to make it easier to fit the extensions and everything and definitely hammered on it just out of pure rage and frustration lol . I remember contemplating just leaving that one out, but once I figured out a good way to get it in there it wasn't too bad.
Old Jan 8, 2019 | 08:36 PM
Originally Posted by JD_AMG
I replaced mine last year (2017), it was a total bitch, I have poly mounts. I think the only one I had real trouble with was the very top center one, in which I used a small swivel extension that I taped up so it wouldn't swivel too freely, and taped the socket to it so it wouldn't come off, and then a regular ~6" straight extension connected to that. I think I started to thread the bolt in by hand and then got the socked on it and used an electric drill to get it as tight as I could. Also I took a hammer to the underside of the car to massage some of the areas to make it easier to fit the extensions and everything and definitely hammered on it just out of pure rage and frustration lol . I remember contemplating just leaving that one out, but once I figured out a good way to get it in there it wasn't too bad.
thats what im afraid of. so if my cradle is out now you would recommend massaging it now for future clutch removal? idk maybe i just get new rubbers lol
Old Jan 8, 2019 | 09:26 PM
00PewterSS's Avatar
I have had the trans out a number of times with poly mounts. I use about 4 feet of extensions and it isn't really that bad... well with the car on a lift. I've never bashed my floor or anything. Hardest bolt for me is the torque arm top clam shell bolt, I hate trying to get that in and out.
Old Jan 8, 2019 | 09:32 PM
what about the top bell housing bolts?
Old Jan 8, 2019 | 09:39 PM
00PewterSS's Avatar
Those are the ones I am talking about. A swivel and a bunch of extensions, maybe a swivel extension actually. Anyway, the angle is pretty shallow... it works.
Old Jan 10, 2019 | 12:58 PM
stoverz28's Avatar
Try loosening up the motor mounts a bit so they will allow you to drop the trans a couple inches. I also always pull the trans from the bellhousing, leaving the bell housing bolted up. This makes those top bolts really easy to get to.
Old Jan 10, 2019 | 05:07 PM
do you have poly mounts? i have no issues with the rubbers
Old Jan 10, 2019 | 07:30 PM
JD_AMG's Avatar
What do you mean the cradle is out? Like you have the engine/trans and Kmember out of the car? If so I would say it isn't a bad idea to do a little hammering then. Although I would just reinstall the engine and trans while the are already mated together outside the car.
Old Jan 10, 2019 | 08:12 PM
correct, but i have plans for an RPS clutch in the future which is why im thinking ahead now
Old Jan 10, 2019 | 08:41 PM
Grifter's Avatar
Lower the k member. I have solid mounts and when I did my clutch I just lowered the k member a little. Simple as that.
Old Jan 10, 2019 | 09:19 PM
you literally just jack it up to transmission removal height? then support the k member, unbolt, then lower a few inches? nothing gets in the way of that? not even brake lines?
Old Jan 13, 2019 | 09:07 AM
stoverz28's Avatar
I have solid mounts in my RX7.
Old Jan 13, 2019 | 09:49 AM
different body style so may not be tight clearance when trying to loosen the bell. i will probably just massage it a little underneath just to be safe
Old Jan 13, 2019 | 07:13 PM
79_T/A's Avatar
I have solid mounts and can still pull the trans with the car on jack stands. For the top bolts, just use a swivel on a really long extension and you’ll be good to go.
Old Jan 13, 2019 | 08:49 PM
so that means with poly they will give a little more making it easier
Old Jan 13, 2019 | 10:08 PM
Rick01SS's Avatar
Get a small magnet and put in the end of the socket.
Old Jan 17, 2019 | 03:27 PM
blkbird's Avatar
I just did an engine swap and found that when the intake is removed, you can get to the top and driver top side bolts fairly easy. Like I said..... I did this during an engine swap with the motor still in car and no intake. Just a thought.......
Old Jan 18, 2019 | 06:28 AM
sounds like a worst case scenario but will keep in mind. that may be something for the solid mount guys though, much better than lowering the k member imo
Old Jan 18, 2019 | 08:46 AM
blkbird's Avatar
I have the prothane motor mounts as well. Just found it easier than fighting those damn bolts from below.
