LS7 Clutch ?s, and Slave Cylinder ?s.
On average is the LS7 assembled clutch with flywheel and the LS1 assembled clutch with flywheel the same height?
Just to confirm that the spring for the tob, makes the tob ride on the pressure plate? And how much clearance should I have for the tob and pressure plate with the spring removed? 0.100",
Thanks.
Thanks.
