Nv3500 ls1 5.7
Nv3500 ls1 5.7
Hi everyone,
I realize putting a NV3500 to an LS engine is not new, and most of the forums about this swap seem pretty dated. Does anyone have a current parts list for a 2004 LS1/ NV3500 swap?
Any help is appreciated.
I did an nv4500 swap, it's pretty close to the same as you. NFW 1050 flywheel and a 2001 Silverado clutch from a 6.0 truck. Internal throwout/ and slave assembly. Russell braided line from master to slave.
Do you happen to remember which throwout bearing you ended up getting? Im having a difficult time finding a 1.125'' internal diameter throwout bearing that isnt 300$
2001 Silverado throwout bearing and internal slave cylinder combo from any parts place should work if you have the internal slave. Got mine on Amazon for $60 I think. If it's external slave with a clutch fork look for a 1991 Chevy 2500 or 3500 manual trans throwout bearing that should get you what you need.
