Master or Slave
I am going to bleed the slave first, but the fact the line is lose concerns me. Also, assuming the line looseness is not the problem, what sort of test or procedure do you take to determine which unit is at fault. Is there a pressure test I can make upon the MS to make sure before I pull the tranny??
There is plastic in the slave?? All slaves?? But does anyone
know what the line pressure should be??
Also, did you have problems when it was cold too?
Second, and obviously, to replace the slave the tranny must come out. So, I thought that I would try the MC first before pulling the tranny (ugh). It was tough. I had to remove the brake booster and brake MC, and then lay on the car floor in an tough position to remove the booster bolts which only moved an eighth of a turn each time.
When I started the car after bleeding, the pedal went to the floor but did not disengage the clutch. After a few restarts, the pedal returned and it has been fine ever since. That was two weeks ago. Thanks for the help.
