Diamond stage 2 clutch review
I've had a LS6 clutch in my 2000 TA for several years. I recently had an issue with the clutch pedal sticking on the floor so I replaced it with a Diamond Stage 2 clutch. The first couple starts had a slight bit of chatter as I was trying not to run the rpms too high. After a couple days driving this clutch is as easy to drive as the LS6 clutch. The pedal effort is just a slight bit more and it seems to engage a slight bit lower than the LS6 clutch even using the supplied shim. If I ease off the clutch engagement is smooth. If I release the clutch quickly I can feel the clutch grab immediately. Anyone needing a clutch for a cammed car should consider this clutch. At $430 it's a real bargain compared to some others.
