Need help figuring out if problem is master or slave cylinder please
Old 05-14-2019 | 08:08 PM
LsxS10blazer's Avatar
Default Need help figuring out if problem is master or slave cylinder please
My pedal went to the floor all of a sudden and I can barley shift it if I have my pedal all the way to the floor and as soon as I barley release pedal it fully engages and there is no smell coming from clutch
I Know it's impossible to diagnose over the internet but was curious if this was for sure the slave or master cylinder
Thank you
Old 05-15-2019 | 07:57 AM
Darth_V8r's Avatar
Moderator
Disconnect the hydraulic line between master and slave. Press clutch pedal in. If it goes in, it's the master. if not, it's the slave.
Old 05-15-2019 | 08:02 AM
Ok I'll try that
thank you
Old 05-15-2019 | 03:43 PM
2ToeRacing's Avatar
I know some people don't do this but its a thought. When ever one of the two go bad I replace both master n slave. I tried to get away with in last year but ended up doing both. I bought GM parts because the originals lasted 18 years so....O and Its a ************ to replace the master but.......
Old 05-15-2019 | 04:12 PM
ddnspider's Avatar
Screw that stupid U-bolt crap on the master.
