GM 24264182 slave cylinder lines
Old 06-19-2019 | 11:40 PM
anubyss's Avatar
Default GM 24264182 slave cylinder lines
I am searching for part numbers for a quick bleed and slave cylinder to master cylinder lines. I was able to find a speed bleeder remote clutch line easily enough (Tick Performance and Hinson) but not the slave cylinder to master cylinder line. Is there a kit or will the fittings have to be purchased separate from the line? The slave cylinder is going to an LS3. Thank you.
Old 06-24-2019 | 02:13 AM
jmd's Avatar
jmd
McLeod makes a line that fits stock early T56 (C5 / F-body) slave and the other end is female AN-3 or 4. That comes with AN to master adapter.
Old 06-24-2019 | 11:21 AM
anubyss's Avatar
Thank you for the info. I ordered Russell 656060 (brake hose) and Russell 640281(fittings) from Amazon. Just in case I ordered a 36" braided SS brake line AN3 from Speedway 91031846-3 as well.
