NV4500 to LC9 but with a 65 clutch and bell housing
I am building a 65 c30 pickup
I am going from a sm420 to a NV4500, up front will be a 5.3, I need to use my original bell housing because it has integral mounts. I have the Advance Adapters plate to go between the trans and bellhousing. I am using a dodge gas input with 10 splines in the 5.61 ratio GM trans with the GM bearing retainer.
What flywheel would I use to be able to retain my stock clutch setup? Will I need a special throwout bearing?
thanks in advance
thanks in advance
