Shift Speed Improvements - Help Me DriverMod
Smaller stuff is easier to shift quick, like a Honda 5 speed manual with tiny speed gears and light clutch disc. Heavier stuff like behind a deseil truck will never be able to be quickly shifted. Strong sychronizers are a key to quick shifting. There job is to match the speed of the gear before it engages. When I'm idling in neutral, disengage clutch and engage 1st. My T56 synchro is so strong I actually hear a bang as the synchro forces my disc to stop spinning instantly.
Another item is a clean break away. At half or less then half clutch pedal travel the disc should be completely free from the pressure plate/flywheel.
Post of a vid of you going through the gears. On a side note speed shifting definately helps ET when the car is going slow, like the 1 to 2. Imagine a slow 1 to 2 vs another car. You will fall back half a car length. A speed shift like 3 to 4 near the traps. Hardly any loss in et slow or fast shift.
