Feelin' stoopid but...
Old Jul 14, 2004 | 10:45 PM
Camaro00_SS's Avatar
Default Feelin' stoopid but...
...I need a diagram of the clutch hydraulics please! My Haynes doesn't show exactly where the slave is located, and the description's not helping me any either!! Got the idea behind the master, I've located that. Going to replace or do drill mod, and I need to know what I'm looking for!
thanks,
Old Jul 15, 2004 | 09:57 AM
Kevyn's Avatar
You have to pull the trans to get to the slave.
It's donut shaped and the input shaft passes thru it.
If you follow the braided hydrauic line from the master you will see it enter the trans. The dicconnect fitting is right there.
You can do the drill mod without pulling the slave. I remember the U-bolt that holds the master being a PITA to get back in place tho.
If you are replacing the slave, I'd do the clutch (if it's old) while the trans is out.
