Bell housing clutch setup LS/TKO600
Can you use a SBC scatter shield on an LS/Tremec Liberty modified tko 600? The engine I'm using made 560HP knowing that and wanting to run a 200 shot @ #3600 what clutch would you recommend. How about a hyd. t/o bearing set up? Going in a 55 Chevy. Thanks for any info in advance! Scott!
