Hydraulics epiphamy...
I've had issues with a low pedal. I tried the speed bleeder but then lost the pedal and had to pump it up. That lead me to believe that somehow I have air in the system. But speed bleeding should push it all out, so I thought. I stumbled on a video on youtube stating that some systems can trap air in the master cylinder and that bleeding won't get it out. This is because the master is laying flat and the air is trapped on top the fluid. Seems a solution is to put the nose of the car higher by jackstands or ramp or incline which angles the master upward. Pumping the pedal will burp a bubble up to the reservoir(kinda like burping a coolant bubble). By the same reasoning, using the Tick speed bleeder at an incline should allow the air to come out the other end of the system.
The following users liked this post:
wannafbody (02-16-2020)
There are a fair number of boogie man theories on clutch hydros.
Your master cylinder is installed at an angle. Toss the flat master theory out.
The pressure of your hydraulic cylinder operated as designed far exceeds:
There's not many places for air to hop into the fray. Under pressure, you'd have pushed fluid out of any of the places possible for air to enter. Which leaves the reservoir hose that does not see master cylinder pressure as a possibility for the draw of air into the system.
If your speed bleeder is feeding to the reservoir fluid so air bubble can self-float away, and aggressive pressure at the pedal is pushing fluid through a one-way bleeder, that should be about it.
- Pressure bleeder vacuum negative pressure.
- Pressure bleeder pressure
- That happy little turkey baster video method.
Moderator
Received 1,851 Likes
I've never tried putting the speed bleeder into the reservoir. I've tried putting it in a half filled bottle of brake fluid. Maybe the reservoir is a better idea.
