Master cylinder hose o ring
I need a part number for the o ring at the end of the hydraulic hose of the master cylinder. This is for a t56 equipped fbody.
Looked on Ticks website and did not see one. After a little reading I found it needs to be made of a material that works with brake fluid so not all orings will work.
so you mean the one at the quick disconnect ?
It's just a regular EPDM o-ring you need. NOT Viton. The Viton will expand ( that said....I did buy viton at first before I found out it wasnt suitable, and I'm near sure it's been on my car since. But I do expect if I need to remove the disconnect...it'll be messy lol.
I bought some a few years ago....I think they were 2.0mm thick, and 12mm ID
