Oversized LS6 Pilot Bearing? 1.705"?
Hey guys, I've got an LS6 in my ASA Stock car that came from Schwanke. I was changing the clutch, and ordered the "large" LS Pilot Bearing, part #12557583. Well, it's too small. OD mic's at 1.650", but the old bearing is 1.705"
On the old bearing it's printed "6302 DU" and "815-115" but all those numbers point to 1.65" OD bearings. It doesn't make any sense. Is there an extra large bearing?
Thanks! It was strange, because when I gave Advance and Autozone the Chevy part number, and even the numbers printed on the old bearing, they pulled 1.650" bearings for me. I made a trip to NAPA this morning, and they pulled the correct bearing.
https://www.napaonline.com/en/p/BRG6...=brg+6302vsp43
That's ok. Try going to oreillys to get a pilot bearing. Dude tried to give me a axle bearing. I told him my hammer is too
Small to make that work. He looked confused. So I told him the hole is like 1-5/8 not 3-1/2 inches. So he brought me a front wheel bearing.
I shoulda known when I said Pontiac travs
And he could not find it - but we do have a firebird if that works!
For instance, my car has an underdrive pulley. The belt frayed and had to be replaced. You could not read the numbers. Even if you could, a big box store would only ask what is the make and year, and could not find the belt by number. I went to my local guy belt in hand and showed it to him. What did he do when he could not read the numbers, got the Gates measuring gauge, stretched the belt on it and found the length, cross referenced the length to a part number, got the long helper stick and took the right sized belt from the upper shelf row. Amazing!!
Later on I called the big box, I won't mention names, and they sold the same belt for two bucks less. Wow are they worth it!! BTW, the belt I bought was a GOODYEAR.
