Clutch help
Old Oct 26, 2020 | 12:18 AM
00_ss_slp's Avatar
Default Clutch help
Hey guys i’m going to purchase a monster level 2 clutch for my 2000 camaro ss, And if I’m not mistaken I believe it comes with the slave cylinder/throwout bearing and the pilot bearing, does anyone know if it comes with the appropriate size shim or if not what would be the appropriate size shim. My clutch isn’t disengaging properly I have replace the slave cylinder and also the master cylinder and Bled it properly, With the help of someone from the form I was able to determine that neither one was the problem that it is the clutch thanks for any info or advice
