t56 to ls7
LS7 is a crate engine right?
What kind of T56 are you using? (What did it come out of?)
What PCM are you using? What did it come in?
What kind of car are you putting this into.
on the back, I believe they are all still 6 bolt for the flywheel. But double check that. I think they swapped over to 8 bolts later on.
guess that part is not super critical as long as you find the proper flywheel and clutch set up.
the t56 is a level 5 t56 from tick performance for 4th gen f bodies
im using a holley hp efi plug and play harness
its going into a cobra kit car
