Mating LS427 to T56...
I attempted to mate the two last night, unsuccessfully. I simply couldn't get the transmission shaft into two clutch plates. Yes, I did use an alignment tool when I installed the clutch. Yes, they visually look aligned and I can still slide the alignment tool in without issue. I just couldn't get the transmission shaft in. I was pretty light-handed in trying to do so. Is this something that should just go together easily or is it something that requires a bit of wrestling and heavy-handedness to get done?
Any tips, tricks, or feedback would be much appreciated. Thanks.
that midplate looks like a magnum midplate
Is there a reason you didn't purchase the Fstyle Magnum? I assume you are keeping the factory console and that is why.... ?
I know I wanted a T56. I loved that trans in my 4th-gen, so when I purchased my engine from GM, I also purchased that trans. Are you speaking of the Tremec-direct T56? I thought there wasn't any real difference? Clarification here would be nice. Oh, and no. I'm not using the factory console. I'm probably not using a console at all. I've already installed the Speedtech T56 trans tunnel.
btw all magnums when purchased as an aftermarket transmission are the same internally, no difference in buying from gm or summit
