L83 t56
Not saying threads here are antiquated, but if we can gain some information from the Vendors, who pay to be here, by all means share the information with others...that's the beauty of collaboration.
All the OP can do is pick up the phone, talk to a professional, and report findings here. If the answer is not answered. Boom, done. Technical problem solved, in either case.
If you gonna just troll, stay in the SRK section. That is where the trolls live. Otherwise, go gape some nerds and report back.
a magnum is different from my transmission but that maybe this info would help. In the end I paid a local transmission shop to do the work (texas drivetrain performance) they charged me around $150 for disassembly and machining (2021) and did not provide the exact dimensions. I installed it at that point and it barely had enough splines left to sit through my Tilton 7.25" tripple disk setup.
Note. if you use certain factory clutches that pair with the tr6060, the flywheel may have a necked down opening that would prevent your input shaft from getting as close to the pilot bearing face. Also, note that I did not have any spacer or those metal plates that sit behind the flywheel which would offset measurements. I just installed bellhousing to engine and transmission to bellhousing.
