Lightweight clutch dyno article I found
Old May 22, 2021 | 02:52 PM
nmass399's Avatar
Default Lightweight clutch dyno article I found
Basically this mimics a clutch on the engine dyno. Saw this and thought people would like to see it
http://www.superchevy.com/how-to/eng...eel-why-weight
Old May 25, 2021 | 11:23 AM
gnx7's Avatar
I love 11lb aluminum flywheels and RXT clutch combos! lightweight flywheel is sooo much more fun to drive. Engine also rev's up waaaaaay faster.
Old May 25, 2021 | 12:01 PM
weedburner's Avatar
Article would have carried much more weight if it had considered typical real world acceleration rates rather than a typical dyno test acceleration rate. I did a series of tests a while back on a couple of otherwise identical sbc engines. One had a 49lb stock crank, heavy 8" balancer, and 1863g bobweight rotating assy, the other a 42lb pendelum style crank, liteweight 6" balancer, 1492g bobweight. Same clutch/flywheel/compression/cam/carb. Basic difference was one had stock crank and steel I beams, the other had sprint car crank with aluminum rods. The 1st gear accel rates of 1975/2217 rpm/sec worked out to a 276ftlb difference between the two, by 3rd gear the accel rates of 535/541 rpm/sec it was only a 6ftlb difference. Wonder what the accel rate was during the article's dyno test?
Grant
Old May 25, 2021 | 02:56 PM
Kawboom's Avatar
Not a GM product but when doing the clutch job I replaced the flywheel in my S197 mustang with a lighter unit from ACT, 8 pounds lighter, and its quite noticeable. Ford should have built the car with this clutch and flywheel, the car even starts better.
Old May 27, 2021 | 09:35 AM
David_viny's Avatar
Engine Masters show Season 5 episode 72 did a test with weight. Been a while since I saw it but from what I remember the standard dyno acceleration rate of 300rpm/sec didnt show much of a change, but at 600rpm/second it showed decent gains. Which makes sense, trying to accelerate a heavier flywheel fast is going to take more power.
