T56 Shifter Vibration
Hello everybody I recently bought a used t56 and everything was good until I did a highway pull up to about 125mph and ever since then now when I’m on highway cruising if I go over 65mph the shifter starts vibrating and as I go faster it gets worse and worse it does this in every gear. I have a new monster stage 3 clutch kit in it with a new slave and a mgw shifter. It vibrates in 3rd, 4th, 5th, and 6th basically anything above 65mph is when I start to notice. Pinion angle is good I got the driveshaft rebalanced put it on jack stands with no wheels and it still does it I can definitely tell it’s coming from the tranny my question is if you guys think it’s fixable or what’s wrong with it. If I can’t figure it out I’ll just save up the money and get it rebuilt by tick performance. The vibration gets so bad that it’ll leak all the tranny fluid out the rear seal if I don’t keep it under 65mph. Thanks in advance!
