T56 use with 99-00 6.0 block?
Read an older post saying the T56 could not be used with 99-00 6.0 block because of longer flange on crankshaft (crank designed for use with 4l80 and other auto trans)...could someone tell me if this means the transmission with not bolt up or is there some other problem with using the T56.
Thanks
Thanks
