Starting Issue.
Old Nov 2, 2021 | 02:43 PM
Spdoflight's Avatar
Default Starting Issue.
New to the forum. Thanks in advance for any help. I have a 2006 GTO with the manual transmission. I just replaced the clutch.. Everything is back together. The car will not start with the key. I can start the car by crossing the solenoid. I have removed the clutch safety switch and have crossed the connector with a paper clip and the car will still not start.. Any suggestions? Is there a connector in the wiring harness around the transmission I may have missed that would explain this this? I have looked very carefully and do not find an open connector. I am baffled. Thanks again
