Clutch slave cylinder line stuck????
Old 02-05-2022, 04:37 PM
matt1289's Avatar
Default Clutch slave cylinder line stuck????
What am I doing wrong here? I've never had this much trouble with this piece of ****...
The white clip is all the way in.
and what is the point of this "quick disconnect tool"? Looks like it only work if you pull the damn transmission...
Old 02-05-2022, 06:02 PM
Floorman279's Avatar
LS1Tech 10 Year
is your bleeder line unscrewed/loosened up
Old 02-05-2022, 06:54 PM
01CamaroSSTx's Avatar
Received 1,948 Likes on 1,400 Posts
Get a fathead screw driver. Push in on the connection while pushing in the plastic tab that is around it and once pressed in you pull on the connection to release it. I could have this backwards and its pry the plastic tab out and pull on the connection but that was the tool I used to remove it.
Old 02-05-2022, 11:53 PM
Received 3,730 Likes on 2,265 Posts
LS1Tech 10 Year
I use an 11/16” line wrench. I put it around the line and place it against the plastic piece. Push against it while pulling on the line. Pops right out every time. I’ve never had an instant of trouble with these things. Takes about 20 seconds.
The following users liked this post:
01CamaroSSTx (02-06-2022)
Old 02-06-2022, 09:35 AM
Couldn't remember if it was push in the tabs or not, I've done this only a few times but I've never had an issue. You have to push in on the connector to free up the tension to push in the tabs then pull to remove.
Old 02-06-2022, 12:59 PM
Save the manuals!
wssix99's Avatar
LS1Tech 10 Year
The first 4 minutes of this will show you how to get it off:
Quick Reply: Clutch slave cylinder line stuck????
