Another T56 to L96 swap
Hey guys,
I know there are a lot of threads about swapping T56 to LS / LT engines, but I could not find the right information for the L96 truck engine. I have the T56 (Borg Warner 13-86-065-902) with the 13-86-172-903 front or mid plate. for the bellhousing I could not find a part no but it seems to be a little bit too small to fit my L96 engine. So I assume it is for the LS engines or maybe aluminum block engines? I have to say honestly that I am not yet familiar with the Gen3 and 4 engines so I am not sure which engines have maybe the same flanges or housings, what makes it even more difficult
If I found the right information, some people used the bellhousing 13-86-212-901-H for LT1 engines with iron block. Some others needed different input shafts, front/mid plates and adjustment shims. Also for the throwout I found different information about shaft sizes, hydraulic throw outs that fit, others say you have to use another shaft, different information on same gearbox. As it is not easy to find all the parts here in the UAE, I just want to avoid buying and trying, maybe someone can help me with part numbers I need to make the conversation.
Hope someone can help with that, thanks a lot guys!
Best regards,
Chris
Best regards,
Chris
